Hi Garazi,
I applied 20 N for 200 seconds using the same brief ramp on and ramp off times as before. I got some meaningful deformation at the end. Can you use longer times instead of cycles?
Look in the Solution Output text near the end and see what it says. Depending on what it says, different corrective actions would be used. If you would like to have a live video chat, I can meet to go over the solution output with you on Google Meet or Skype. Reply with your email address and I will contact you. You can delete your email address as soon as I have it.
