Ansys divides GPUs into two categories, one for display and one for accelerating computation.  Ansys tests a limited number of GPUs and lists the ones tested in a document.
Here is the pdf file that has the display adapters:
https://www.ansys.com/content/dam/it-solutions/platform-support/2022-r2-graphical-display-graphics-cards-tested.pdf
While a GeForce card will probably work for the display, it hasn’t been tested. In a professional environment, cards from the published list are recommended.
Here is the pdf file that has the list of GPU accelerator cards
https://www.ansys.com/content/dam/it-solutions/platform-support/previous-releases/ansys-2022-r2-gpu-accelerator-capabilities.pdf
In the past, these two lists had separate cards, but now I see the Nvidia RTX A4000 card is on both the display list and the accelerator list for Fluent!  This card has 16GB of GPU memory, so that might be a better choice for your needs than the RTX 4000 which has 8GB of GPU memory.
