David Weed
Hello, for interface delamination, if you're using interface elements (INTER20X), the only output parameters available are separation parameters. We don't have direct output for crack extension (for this you may want to consider the VCCT method for delamination instead).
However, if you are also interested in plotting the separation parameters for interface elements, you can use a user-defined result to do so. See the documentation for INTER202 (table 202.1): https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/ans_elem/Hlp_E_INTER202.html
With this, you can plot the separation between nodes:
