John Doyle
Below is the documentation for AMBUILD. If you open the "ds.dat" file in your solver directory, perhaps this command is overriding your G-Code.   If you add "AMBUILD,time,val1", consistent with this doc,in a command object under Environment Branch, it should override this default.  It should be executed right before the solve.
