sagar.gupta.satrasala
Thanks it worked, but I am getting an error when i mesh - "The source mesh cannot be correctly copied to the target surface. This might be because the surface is a closed surface with degenerate points. Splitting the surface might help".
Can you also please tell me why you created a ZX plane with an offset of 100mm and split it.
Even in the file you sen, when I mesh I am getting this error
