Apply a Force or Pressure to any surface that experiences a harmonic input load. Enter the amplitude of that force or pressure in the Details and the Harmonic Response analysis will sweep that amplitude from the start frequency to the end frequency you specified under Analysis Settings and calculate the harmonic response over the entire structure for displacement, velocity, acceleration as well as stress if you set the corresponding output requests under Analysis Settings.
