Nikhil Narale
Hi, what do you mean by consistent? Are you comparing this with other similar simulations? If so, are you changing any settings?
'does it mean that the particles do not reach the wall?'
This depends on which forces are dominant. If the weight of the particles dominates over the pressure-gradient force of the continuous fluids, it should reach the wall (provided you have defined gravity correctly)
