Nikhil Narale
I am not an expert, but can check if this tutorial example can be used as a reference? See how the fluidized bed is set up. Chapter 24: Using the Eulerian Granular Multiphase Model with Heat Transfer (ansys.com)
If you are not able to access the link, refer to this forum discussion: Using Help with links (ansys.com)
If this doen't work for you, let's wait for experts to pitch in.
Nikhil
