In which case it's possibly the UDF recalculating based on cell values on restart. Check the flow gradients and DPM source terms, you may need to increase the parcel count and/or refine the mesh to capture all of the gradients.
However, if the average is jumping around as per the second graph I suspect it's either unstable or slightly transient which won't help.
