In which case I'm not sure. Is the run period to the failure roughly similar in all cases?
There aren't any instructions for running Fluent stand alone, well, there are some in the manual but I'm not sure they're needed! In Workbench use File>Export>Case&Data. Launch Fluent from the Start menu, then read case & data. The rest is much the same.
