javat33489
Thanks for the answer.
I'm a little confused. But already understood.
I have two questions.
  1. How is the damping factor calculated? How to define it? Or is it usually 1-2%?
  2. 2. I want to transfer the load from the pump to the pipe. I have a tabular data that is PERMISSIBLE VIBRATION AMPLITUDE 60 microns. Can I set this load only using displacement? Or should I make this load a function of the frequency? And how to do it?
