Erik Kostson
Can you set under the Analysis settings and output controls all to Yes. I think even with that it does not show.
The reason might be as per the help manual under strain energy section, that it includes plastic strain which we can not have in a harmonic analysis (only linear material).
One can add perhaps some user defined results – see worksheet summary under the solution in the mechanical tree and there should be some energy results (e.g., ENERGYPOTENTIAL).
Erik
