Yes, you can use a displacement B.C. of 60 microns on the surface the pump mounts to. You might want to run that displacement in 3 different directions. The 60 microns will be used in a frequency sweep from the lowest to the highest frequency in your analysis.  Note that the acceleration that this displacement B.C. creates goes up as the square of the frequency.
