Judy Cooper
Hi Austin:
Closed Homgeneous batch reactors are intended for homegeneous processes, so there is no spatial component.  To add a spatial component to the combustion, a different Chemkin model is required
2.3.5. Burner-stabilized Flame
Flame propagation in Chemkin can be done using the Flame Speed Library Reactor model.
2.3.9. Parameter Study: Propane/Air Flame Speed as a Function of Equivalence Ratio and Unburned Gas Temperature
This allows you to plot species change across the flamefront:
Both are diffusion flames.  Flame propagation is fundementally a 3D process, and should be modelled with rull CFD.  Chemkin can be used to generate the required flame library information to make the CFD calculations accurate, however.
Best Regards,
Judy
