SaiD
Thanks for sharing the images. I am not sure if this will help, but can you try using "Multizone method" for the bolts to mesh it with hex elements? Even the horizontal cylinder can probably be meshed with hex elements if Sweep (Axissymmetric) or Multizone method are used.
Altering the mesh might help fix the problem.
