SaiD
In your image, the third message I see is an 'Excessive element distortion' error. That could be why your simulation is not converging.
You might find the following video helpful: How to Handle Element Distortion Errors in Hyperelastic Materials — Lesson 3 - ANSYS Innovation Courses
The same course has other lessons about setting up a model that uses a hyperelastic material, you can check those out too and see if you find anything helpful.
Hope this helps.
