mehdi.salakhi
This is the sequence of the operation:
  1. Export the CFD solution data as CGNS file
  2. Loading Ansys Energico
  3. Preprocessing my chemistry using Utility in Enegico (which works fine)
  4. Selecting working directory, cgns file, and chemistry in Select Files
  5. When energico tries to load my data, at half of the way, I get this error
mechanism:
I have been using a reaction mechanism called KAUST (chemistry input + thermodynamics data)
I was able to run energico in another case that had a different CFD solution
I appreciate your help here!
