Waled Raban
If you are referring to accessing the Ansys Customer Portal or Ansys Licensing Portal, then adding or removing of account admins is self-serve. You may log into the Licensing Portal, find the License Portal Access section and add/remove admins in there. If you are completely locked out of the Licensing Portal, then you must contact your Ansys account manager via email to make this request.
