yuriporto
Hi Mike! I have the same problem, I tried to do what you said but it didn't work. My Ansys is 16.2. My computer config is:
-AMD Ryzen 5 4600H with Radeon Graphics            3.00 GHz
-16.0 GB (utilizável: 15.4 GB)
-GTX 1650 (4gb)
This is my log file:
PLEASE, HELP!
_____________________________________________________
 Release 16.2
 Point Releases and Patches installed:
 ANSYS, Inc. Products Release 16.2
 ANSYS Mechanical Products Release 16.2
 ANSYS Customization Files for User Programmable Features Release 16.2
 ANSYS Autodyn Release 16.2
 ANSYS LS-DYNA Release 16.2
 ANSYS Composite PrepPost Release 16.2
 Catia, Version 6 Release 16.2
 ANSYS, Inc. License Manager Release 16.2
          *****  ANSYS COMMAND LINE ARGUMENTS  *****
  BATCH MODE REQUESTED (-b)    = NOLIST
  INPUT FILE COPY MODE (-c)    = COPY
  SHARED MEMORY PARALLEL REQUESTED
    SINGLE PROCESS WITH   2 THREADS REQUESTED
    TOTAL OF     2 CORES REQUESTED
  MEMORY REQUESTED (MB)        = 1000
  START-UP FILE MODE           = NOREAD
  STOP FILE MODE               = NOREAD
  DATABASE SIZE REQUESTED (MB) = 100
 RELEASE= Release 16.2         BUILD= 16.2      UP20150629   VERSION=WINDOWS x64
 CURRENT JOBNAME=file  21:57:56  OCT 23, 2022 CP=      1.297
 PARAMETER _DS_PROGRESS =     999.0000000
 /INPUT FILE= ds.dat  LINE=       0
 DO NOT WRITE ELEMENT RESULTS INTO DATABASE
 *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  21.9655556
 TITLE=
 Montagem Guia de Palete Final Completa R0--Static Structural (A5)
  ACT Extensions:
 SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
  TYPE=STRI  DIMENSIONS=      248        1        1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:\Users\yurip\OneDrive\PROJETOS\CE-PR-22-333 - GUIA PARA APOIO DE PALETES\2 - ELABORACAO\_ProjectScratch\Scr9E74\
 SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = C:\Users\yurip\OneDrive\PROJETOS\CE-PR-22-333 - GUIA PARA APOIO DE PALETES\2 - ELABORACAO\Montagem Guia de Palete Final Completa R0_files\dp0\SYS\MECH\
 SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = C:\Users\yurip\OneDrive\PROJETOS\CE-PR-22-333 - GUIA PARA APOIO DE PALETES\2 - ELABORACAO\Montagem Guia de Palete Final Completa R0_files\user_files\
 --- Data in consistent NMM units. See Solving Units in the help system for more
 MPA UNITS SPECIFIED FOR INTERNAL
  LENGTH      = MILLIMETERS (mm)
  MASS        = TONNE (Mg)
  TIME        = SECONDS (sec)
  TEMPERATURE = CELSIUS (C)
  TOFFSET     = 273.0
  FORCE       = NEWTON (N)
  HEAT        = MILLIJOULES (mJ)
 INPUT  UNITS ARE ALSO SET TO MPA
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE Release 16.2     16.2     ***
 ANSYS Multiphysics
 00000000  VERSION=WINDOWS x64   21:57:56  OCT 23, 2022 CP=      1.406
          ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "Longarina" ***********
 *********** Elements for Body 2 "Longarina" ***********
 *********** Elements for Body 3 "Garra 2" ***********
 *********** Elements for Body 4 "Garra 2" ***********
 *********** Elements for Body 5 "Chapa Refore7o" ***********
 *********** Elements for Body 6 "Chapa Refore7o" ***********
 *********** Elements for Body 7 "Chapa Principal" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Set Reference Temperature ***********
 *********** Send Materials ***********
 *********** Create Contact "Contact Region" ***********
             Real Constant Set For Above Contact Is 10 & 9
 *********** Create Contact "Contact Region 2" ***********
             Real Constant Set For Above Contact Is 12 & 11
 *********** Create Contact "Contact Region 3" ***********
             Real Constant Set For Above Contact Is 14 & 13
 *********** Create Contact "Contact Region 4" ***********
             Real Constant Set For Above Contact Is 16 & 15
 *********** Create Contact "Contact Region 5" ***********
             Real Constant Set For Above Contact Is 18 & 17
 *********** Create Contact "Contact Region 6" ***********
             Real Constant Set For Above Contact Is 20 & 19
 *********** Create Remote Point "Internal Remote Point" ***********
 *********** Create Remote Point "Internal Remote Point 2" ***********
 *********** Create Remote Point "Internal Remote Point 3" ***********
 *********** Construct Remote Force Using RBE3/CERIG Contact ***********
 *********** Construct Remote Displacement Using RBE3/CERIG Contact ***********
 *** Create a component for all remote displacements ***
 ***** ROUTINE COMPLETED *****  CP =         2.031
 --- Number of total nodes = 49084
 --- Number of contact elements = 9789
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 18145
 --- Number of total elements = 27937
 *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  21.9655556
 *************************    SOLUTION       ********************************
 *****  ANSYS SOLUTION ROUTINE  *****
 PERFORM A STATIC ANALYSIS
  THIS WILL BE A NEW ANALYSIS
 USE A MAXIMUM OF     1 EQUILIBRIUM ITERATIONS EACH SUBSTEP
 *** WARNING ***                         CP =       2.062   TIME= 21:57:56
 Using 1 iteration per substep may result in unconverged solutions for
 nonlinear analysis and the program may not indicate divergence in this
 case.  Check your results.
 DO NOT USE PREDICTOR METHOD FOR  ALL DEGREES OF FREEDOM
 USE SPARSE MATRIX DIRECT SOLVER
 CONTACT INFORMATION PRINTOUT LEVEL       1
 NLDIAG: Nonlinear diagnostics CONT option is set to ON.
         Writing frequency : each ITERATION.
 DO NOT SAVE ANY RESTART FILES AT ALL
 ******************* SOLVE FOR LS 1 ****************
 SELECT       FOR ITEM=NODE COMPONENT=
  IN RANGE     49084 TO      49084 STEP          1
          1  NODES (OF      49084  DEFINED) SELECTED BY  NSEL  COMMAND.
 SPECIFIED NODAL LOAD FX   FOR SELECTED NODES         1 TO    49084 BY        1
  SET ACCORDING TO TABLE PARAMETER = _LOADVARI86X
 SPECIFIED NODAL LOAD FY   FOR SELECTED NODES         1 TO    49084 BY        1
  SET ACCORDING TO TABLE PARAMETER = _LOADVARI86Y
 SPECIFIED NODAL LOAD FZ   FOR SELECTED NODES         1 TO    49084 BY        1
  SET ACCORDING TO TABLE PARAMETER = _LOADVARI86Z
 ALL SELECT   FOR ITEM=NODE COMPONENT=
  IN RANGE         1 TO      49084 STEP          1
      49084  NODES (OF      49084  DEFINED) SELECTED BY NSEL  COMMAND.
 SPECIFIED CONSTRAINT UX   FOR SELECTED NODES     49082 TO    49082 BY        1
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI67UX
 SPECIFIED CONSTRAINT UY   FOR SELECTED NODES     49082 TO    49082 BY        1
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI67UY
 SPECIFIED CONSTRAINT UZ   FOR SELECTED NODES     49082 TO    49082 BY        1
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI67UZ
 SPECIFIED CONSTRAINT UX   FOR SELECTED NODES     49083 TO    49083 BY        1
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI70UX
 SPECIFIED CONSTRAINT UY   FOR SELECTED NODES     49083 TO    49083 BY        1
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI70UY
 SPECIFIED CONSTRAINT UZ   FOR SELECTED NODES     49083 TO    49083 BY        1
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI70UZ
 *********** Create Acceleration ***********
 SET PARAMETER DIMENSIONS ON  _ACELX TYPE=TABL  DIMENSIONS=     2     1     1
  TIME
 PARAMETER _ACELX(1,0,1) =     0.000000000
 PARAMETER _ACELX(2,0,1) =     1.000000000
 PARAMETER _ACELX(1,1,1) =     0.000000000
 PARAMETER _ACELX(2,1,1) =     0.000000000
 SET PARAMETER DIMENSIONS ON  _ACELY TYPE=TABL  DIMENSIONS=     2     1     1
  TIME
 PARAMETER _ACELY(1,0,1) =     0.000000000
 PARAMETER _ACELY(2,0,1) =     1.000000000
 PARAMETER _ACELY(1,1,1) =     0.000000000
 PARAMETER _ACELY(2,1,1) =     9806.650000
 SET PARAMETER DIMENSIONS ON  _ACELZ TYPE=TABL  DIMENSIONS=     2     1     1
  TIME
 PARAMETER _ACELZ(1,0,1) =     0.000000000
 PARAMETER _ACELZ(2,0,1) =     1.000000000
 PARAMETER _ACELZ(1,1,1) =     0.000000000
 PARAMETER _ACELZ(2,1,1) =     0.000000000
 ACELX IS SET ACCORDING TO TABLE PARAMETER = _ACELX
 ACELY IS SET ACCORDING TO TABLE PARAMETER = _ACELY
 ACELZ IS SET ACCORDING TO TABLE PARAMETER = _ACELZ
 PRINTOUT RESUMED BY /GOP
 USE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
 FOR AUTOMATIC TIME STEPPING:
   USE      1 SUBSTEPS AS A MAXIMUM
   USE      1 SUBSTEPS AS A MINIMUM
 TIME=  1.0000
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
   FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 NONLINEAR STABILIZATION CONTROL:
 KEY=OFF
 *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000
 *IF  ANSINTER_                         ( =   0.00000     )  NE
      0                                 ( =   0.00000     )  THEN
 *ENDIF
 *****  ANSYS SOLVE    COMMAND  *****
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** NOTE ***                            CP =       2.156   TIME= 21:57:56
 The model data was checked and warning messages were found.
  Please review output or errors file (
 PALETES\2 - ELABORACAO\_ProjectScratch\Scr9E74\file.err ) for these
 warning messages.
 *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
      --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
 ELEMENT TYPE    1 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
  KEYOPT(1-12)=    0    0    0    0    0    0    0    0    0    0    0    0
 ELEMENT TYPE    2 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE    3 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 HYPERELASTIC MATERIALS. NO SUGGESTION IS AVAILABLE AND NO RESETTING IS NEEDED.
 ELEMENT TYPE    4 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE    5 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE    6 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE    7 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 ELEMENT TYPE    8 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ANSYS Multiphysics
 00000000  VERSION=WINDOWS x64   21:57:56  OCT 23, 2022 CP=      2.156
                       S O L U T I O N   O P T I O N S
   PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
   DEGREES OF FREEDOM. . . . . . UX   UY   UZ   ROTX ROTY ROTZ
   ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
   OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
   EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
   NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
   GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
 *** WARNING ***                         CP =       2.219   TIME= 21:57:56
 Material number 10 (used by element 18149 ) should normally have at
 least one MP or one TB type command associated with it.  Output of
 energy by material may not be available.
 *** NOTE ***                            CP =       2.312   TIME= 21:57:57
 The step data was checked and warning messages were found.
 warning messages.
 This nonlinear analysis defaults to using the full Newton-Raphson
 solution procedure.  This can be modified using the NROPT command.
 The conditions for direct assembly have been met.  No .emat or .erot
 files will be produced.
 *** NOTE ***                            CP =       2.406   TIME= 21:57:57
 Internal nodes from 49085 to 49087 are created.
 3 internal nodes are used for handling degrees of freedom on pilot
 nodes of rigid target surfaces.
                      L O A D   S T E P   O P T I O N S
   LOAD STEP NUMBER. . . . . . . . . . . . . . . .     1
   TIME AT END OF THE LOAD STEP. . . . . . . . . .  1.0000
   AUTOMATIC TIME STEPPING . . . . . . . . . . . .    ON
      INITIAL NUMBER OF SUBSTEPS . . . . . . . . .     1
      MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . .     1
      MINIMUM NUMBER OF SUBSTEPS . . . . . . . . .     1
   MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . .     1
   STEP CHANGE BOUNDARY CONDITIONS . . . . . . . .    NO
   TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)
   CONVERGENCE CONTROLS. . . . . . . . . . . . . .USE DEFAULTS
   INERTIA LOADS                        X           Y           Z
      ACEL . . . . . . . . . . . ._ACELX      _ACELY      _ACELZ
   PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
   DATABASE OUTPUT CONTROLS
      ITEM     FREQUENCY   COMPONENT
       ALL       NONE
      NSOL        ALL
      RSOL        ALL
      STRS        ALL
      EPEL        ALL
      EPPL        ALL
 SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
 *** WARNING ***                         CP =       3.312   TIME= 21:57:57
 Node 32379 connects both contact element 25181 and target element
 25272.  Please check the model carefully.
 *** NOTE ***                            CP =       3.328   TIME= 21:57:57
 It is highly recommended to use the auto contact setting option by
 issuing CNCHECK,AUTO command for this problem in order to achieve
 better convergence.
 Symmetric Deformable- deformable contact pair identified by real
 constant set 9 and contact element type 9 has been set up.  The
 companion pair has real constant set ID 10.  Both pairs should have
 the same behavior.
 ANSYS will deactivate the current pair and keep its companion pair,
 resulting in asymmetric contact.
 Contact algorithm: Augmented Lagrange method
 Contact detection at: Gauss integration point
 Contact stiffness factor FKN                  10.000
 The resulting initial contact stiffness      0.12596E+08
 Default penetration tolerance factor FTOLN   0.10000
 The resulting penetration tolerance          0.26875
 Default opening contact stiffness OPSF will be used.
 Default tangent stiffness factor FKT          1.0000
 Default elastic slip factor SLTOL            0.50000E-02
 The resulting elastic slip                   0.44792E-01
 Update contact stiffness at each iteration
 Default Max. friction stress TAUMAX          0.10000E+21
 Average contact surface length                8.9584
 Average contact pair depth                    2.6875
 Default pinball region factor PINB           0.25000
 The resulting pinball region                 0.67188
 Initial penetration/gap is excluded.
 Bonded contact (always) is defined.
 Max.  Initial penetration 1.421085472E-14 was detected between contact
 element 18802 and target element 20006.
 Max.  Geometric gap 0.787994813 has been detected between contact
 element 18910 and target element 20435.
 *WARNING*: The geometric gap/penetration is larger than the pair based
 pinball.  Please verify the pinball radius carefully.
 *WARNING*: The geometric gap/penetration may be too large.  Increase
 pinball radius if it is a true geometric gap/penetration.  Decrease
 pinball if it is a false one.
 constant set 10 and contact element type 9 has been set up.  The
 companion pair has real constant set ID 9.  Both pairs should have the
 same behavior.
 ANSYS will keep the current pair and deactivate its companion pair,
 The resulting penetration tolerance          0.31756
 The resulting elastic slip                   0.45948E-01
 Average contact surface length                9.1896
 Average contact pair depth                    3.1756
 The resulting pinball region                 0.79390
 Max.  Initial penetration 2.842170943E-14 was detected between contact
 element 19257 and target element 18356.
 Max.  Geometric gap 0.806958205 has been detected between contact
 element 19792 and target element 18462.
 constant set 11 and contact element type 11 has been set up.  The
 companion pair has real constant set ID 12.  Both pairs should have
 the same behavior.
 The resulting initial contact stiffness      0.12638E+08
 element 21302 and target element 22821.
 Max.  Geometric gap 0.787994824 has been detected between contact
 element 21241 and target element 22582.
 constant set 12 and contact element type 11 has been set up.  The
 companion pair has real constant set ID 11.  Both pairs should have
 the same behavior.
 The resulting penetration tolerance          0.31650
 The resulting elastic slip                   0.45945E-01
 Average contact surface length                9.1890
 Average contact pair depth                    3.1650
 The resulting pinball region                 0.79125
 element 21979 and target element 20850.
 Max.  Geometric gap 0.806958096 has been detected between contact
 element 21918 and target element 20732.
 constant set 13 and contact element type 13 has been set up.  The
 companion pair has real constant set ID 14.  Both pairs should have
 the same behavior.
 The resulting initial contact stiffness      0.96877E+07
 The resulting penetration tolerance          0.36452
 The resulting elastic slip                   0.39399E-01
 Average contact surface length                7.8798
 Average contact pair depth                    3.6452
 The resulting pinball region                 0.91131
 Max.  Initial penetration 4.29173E-03 was detected between contact
 element 23374 and target element 23989.
 You may move entire target surface by : x= 0, y= 4.29173E-03, z= 0,to
 reduce initial penetration.
 Max.  Geometric gap 5.788153707E-02 has been detected between contact
 element 23546 and target element 23997.
 constant set 14 and contact element type 13 has been set up.  The
 companion pair has real constant set ID 13.  Both pairs should have
 the same behavior.
 The resulting penetration tolerance          0.41289
 The resulting elastic slip                   0.68762E-01
 Average contact surface length                13.752
 Average contact pair depth                    4.1289
 The resulting pinball region                  1.0322
 element 23825 and target element 22997.
 You may move entire target surface by : x= 4.45938946E-18, y=
 -4.29173E-03, z= 9.270350961E-18,to reduce initial penetration.
 constant set 15 and contact element type 15 has been set up.  The
 companion pair has real constant set ID 16.  Both pairs should have
 the same behavior.
 The resulting initial contact stiffness      0.94878E+07
 The resulting penetration tolerance          0.36348
 The resulting elastic slip                   0.39341E-01
 Average contact surface length                7.8683
 Average contact pair depth                    3.6348
 The resulting pinball region                 0.90869
 element 24466 and target element 25062.
 You may move entire target surface by : x= 6.559452688E-18, y=
 4.29173E-03, z= 3.373432792E-18,to reduce initial penetration.
 element 24449 and target element 25029.
 constant set 16 and contact element type 15 has been set up.  The
 companion pair has real constant set ID 15.  Both pairs should have
 the same behavior.
 The resulting penetration tolerance          0.42160
 The resulting elastic slip                   0.70063E-01
 Average contact surface length                14.013
 Average contact pair depth                    4.2160
 The resulting pinball region                  1.0540
 element 24914 and target element 24099.
 You may move entire target surface by : x= -9.001925269E-18, y=
 -4.29173E-03, z= -9.270351102E-18,to reduce initial penetration.
 constant set 17 and contact element type 17 has been set up.  The
 companion pair has real constant set ID 18.  Both pairs should have
 the same behavior.
 *WARNING*: Certain nodes (for example 32381) are used in both contact
 and target elements.  Please check your model carefully.
 The resulting initial contact stiffness      0.73018E+07
 The resulting penetration tolerance          0.54781
 The resulting elastic slip                   0.22747E-01
 Average contact surface length                4.5495
 Average contact pair depth                    5.4781
 The resulting pinball region                  1.3695
 Min.  Initial gap 7.069342494E-03 was detected between contact element
 25185 and target element 25263.
 The gap is closed due to initial settings.
 Max.  Geometric gap 0.714602 has been detected between contact element
 25176 and target element 25254.
 constant set 18 and contact element type 17 has been set up.  The
 companion pair has real constant set ID 17.  Both pairs should have
 the same behavior.
 The resulting penetration tolerance          0.45134
 The resulting elastic slip                   0.74530E-01
 Average contact surface length                14.906
 Average contact pair depth                    4.5134
 The resulting pinball region                  1.1284
 Min.  Initial gap 5.185580282E-02 was detected between contact element
 25216 and target element 25165.
 25204 and target element 25159.
 constant set 19 and contact element type 19 has been set up.  The
 companion pair has real constant set ID 20.  Both pairs should have
 the same behavior.
 *WARNING*: Certain nodes (for example 32414) are used in both contact
 The resulting initial contact stiffness      0.70241E+07
 The resulting penetration tolerance          0.56947
 The resulting elastic slip                   0.19626E-01
 Average contact surface length                3.9251
 Average contact pair depth                    5.6947
 The resulting pinball region                  1.4237
 25318 and target element 25398.
 25310 and target element 25388.
 constant set 20 and contact element type 19 has been set up.  The
 companion pair has real constant set ID 19.  Both pairs should have
 the same behavior.
 The resulting penetration tolerance          0.44359
 The resulting elastic slip                   0.73398E-01
 Average contact surface length                14.680
 Average contact pair depth                    4.4359
 The resulting pinball region                  1.1090
 25352 and target element 25298.
 25337 and target element 25294.
 Force-distributed-surface identified by real constant set 21 and
 contact element type 21 has been set up.  The pilot node 49082 is used
 to apply the force.  Internal MPC will be built.
 The used degrees of freedom set is  UX   UY   UZ   ROTX ROTY ROTZ
 Please verify constraints (including rotational degrees of freedom)
  on the pilot node by yourself.
 Force-distributed-surface identified by real constant set 23 and
 contact element type 23 has been set up.  The pilot node 49083 is used
 Force-distributed-surface identified by real constant set 25 and
 contact element type 25 has been set up.  The pilot node 49084 is used
 *** WARNING ***                         CP =       3.375   TIME= 21:57:57
 Too many nodes 4562 are included in the force-distributed-surface
 constraint identified by real constant set 25.  This may greatly
 affect solver performance.
 The FEA model contains 0 external CE equations and 18 internal CE
 equations.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET           9
 *** NOTE ***                            CP =       6.625   TIME= 21:57:59
 Contact pair is inactive.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          10
 Max.  Penetration of -2.273736754E-13 has been detected between contact
 element 19117 and target element 18225.
 Max.  Geometrical gap of 0.784410245 has been detected between contact
 element 19740 and target element 18427.
 *WARNING*: The geometrical gap may be too large.  Increase pinball if
 it is a true geometrical gap.  Decrease pinball if it is a false one.
 For total 720 contact elements, there are 671 elements are in contact.
 There are 671 elements are in sticking.
 Contacting area 23831.0436.
 Max.  Pinball distance 0.79390082.
 One of the contact searching regions contains at least 14 target
 elements.
 Max.  Pressure/force 2.864006054E-06.
 Max.  Normal stiffness 12596031.8.
 Min.  Normal stiffness 12596031.8.
 Max.  Tangential stiffness 3264561.03.
 Min.  Tangential stiffness 3264561.03.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          11
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          12
 Max.  Penetration of -2.294134795E-13 has been detected between contact
 element 21938 and target element 20584.
 Max.  Geometrical gap of 0.784410256 has been detected between contact
 element 21882 and target element 20762.
 Max.  Pinball distance 0.791252789.
 elements.
 Max.  Pressure/force -2.900947184E-06.
 Max.  Normal stiffness 12638186.1.
 Min.  Normal stiffness 12638186.1.
 Max.  Tangential stiffness 3264784.97.
 Min.  Tangential stiffness 3264784.97.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          13
 Max.  Penetration of 0 has been detected between contact element 23353
 and target element 23957.
 Max.  Geometrical gap of 5.788153707E-02 has been detected between
 contact element 23546 and target element 23997.
 Max.  Geometrical penetration of -4.29173E-03 has been detected between
 For total 386 contact elements, there are 284 elements are in contact.
 There are 284 elements are in sticking.
 Contacting area 6898.18847.
 Max.  Pinball distance 0.911307824.
 One of the contact searching regions contains at least 19 target
 elements.
 Max.  Pressure/force -2.221325207E-06.
 Max.  Normal stiffness 9687721.26.
 Min.  Normal stiffness 9687721.26.
 Max.  Tangential stiffness 3361208.15.
 Min.  Tangential stiffness 3361208.15.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          14
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          15
 Max.  Penetration of -1.146464231E-13 has been detected between contact
 element 24654 and target element 25123.
 contact element 24449 and target element 25029.
 Max.  Pinball distance 0.908688416.
 elements.
 Max.  Pressure/force -2.176620157E-06.
 Max.  Normal stiffness 9487760.36.
 Min.  Normal stiffness 9487760.36.
 Max.  Tangential stiffness 3287159.51.
 Min.  Tangential stiffness 3287159.51.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          16
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          17
 Max.  Penetration of -1.136868377E-13 has been detected between contact
 element 25172 and target element 25241.
 Max.  Geometrical gap of 1.09706984 has been detected between contact
 element 25187 and target element 25262.
 For total 20 contact elements, there are 20 elements are in contact.
 There are 20 elements are in sticking.
 Contacting area 294.849401.
 Max.  Pinball distance 1.3695207.
 One of the contact searching regions contains at least 17 target
 elements.
 Max.  Pressure/force -2.174898095E-06.
 Max.  Normal stiffness 7301824.64.
 Min.  Normal stiffness 7301824.64.
 Max.  Tangential stiffness 6594178.43.
 Min.  Tangential stiffness 6594178.43.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          18
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          19
 Max.  Penetration of -2.978567964E-13 has been detected between contact
 element 25316 and target element 25397.
 Max.  Pinball distance 1.4236775.
 elements.
 Max.  Pressure/force 2.092164814E-06.
 Max.  Normal stiffness 7024062.7.
 Min.  Normal stiffness 7024062.7.
 Max.  Tangential stiffness 7643024.4.
 Min.  Tangential stiffness 7643024.4.
  SUMMARY FOR CONTACT PAIR IDENTIFIED BY REAL CONSTANT SET          20
                         ***********  PRECISE MASS SUMMARY  ***********
   TOTAL RIGID BODY MASS MATRIX ABOUT ORIGIN
               Translational mass               |   Coupled translational/rotational mass
        0.81773E-02    0.0000        0.0000     |     0.0000      -0.27255      -0.34260
         0.0000       0.81773E-02    0.0000     |    0.27255        0.0000       -8.1713
         0.0000        0.0000       0.81773E-02 |    0.34260        8.1713        0.0000
                                                |         Rotational mass (inertia)
                                                |     1478.1        342.56       -272.34
                                                |     342.56        9643.7        11.420
                                                |    -272.34        11.420        8216.8
   TOTAL MASS = 0.81773E-02
     The mass principal axes coincide with the global Cartesian axes
   CENTER OF MASS (X,Y,Z)=   -999.27        41.896       -33.330
   TOTAL INERTIA ABOUT CENTER OF MASS
         1454.7       0.21538       0.11299E-01
        0.21538        1469.3       0.10823E-02
        0.11299E-01   0.10823E-02    37.109
     The inertia principal axes coincide with the global Cartesian axes
  *** MASS SUMMARY BY ELEMENT TYPE ***
  TYPE      MASS
     1  0.107837E-02
     2  0.107836E-02
     3  0.900226E-03
     4  0.900314E-03
     5  0.166128E-03
     6  0.166128E-03
     7  0.388323E-02
     8  0.449020E-05
 Range of element maximum matrix coefficients in global coordinates
 Maximum = 525369676 at element 21624.
 Minimum = 294576.651 at element 17506.
   *** ELEMENT MATRIX FORMULATION TIMES
  TYPE    NUMBER   ENAME      TOTAL CP  AVE CP
     1      1104  SOLID186      0.438   0.000396
     2      1104  SOLID186      0.562   0.000510
     3      4071  SOLID187      0.781   0.000192
     4      4099  SOLID187      0.812   0.000198
     5        74  SOLID186      0.062   0.000845
     6        66  SOLID186      0.062   0.000947
     7      7595  SOLID187      1.672   0.000220
     8        32  SOLID186      0.000   0.000000
     9      1204  CONTA174      0.281   0.000234
    10      1204  TARGE170      0.031   0.000026
    11      1204  CONTA174      0.250   0.000208
    12      1204  TARGE170      0.031   0.000026
    13       548  CONTA174      0.062   0.000114
    14       548  TARGE170      0.000   0.000000
    15       544  CONTA174      0.094   0.000172
    16       544  TARGE170      0.000   0.000000
    17        67  CONTA174      0.000   0.000000
    18        67  TARGE170      0.000   0.000000
    19        66  CONTA174      0.000   0.000000
    20        66  TARGE170      0.000   0.000000
    21       160  CONTA174      0.031   0.000195
    22         1  TARGE170      0.000   0.000000
    23       176  CONTA174      0.000   0.000000
    24         1  TARGE170      0.000   0.000000
    25      2187  CONTA174      0.078   0.000036
    26         1  TARGE170      0.000   0.000000
 Time at end of element matrix formulation CP = 6.625.
     FORCE CONVERGENCE VALUE  =  88.94      CRITERION= 0.4538
 SPARSE MATRIX DIRECT SOLVER.
  Number of equations =      147237,    Maximum wavefront =   3858
 *** NOTE ***                            CP =       8.125   TIME= 21:58:00
 The initial memory allocation (-m) has been exceeded.
  Supplemental memory allocations are being used.
  Memory allocated for solver =        1353.781 MB
  Memory required for in-core =         767.499 MB
  Memory required for out-of-core =     136.060 MB
 *** NOTE ***                            CP =      10.203   TIME= 21:58:02
 The Sparse Matrix solver is currently running in the in-core memory
 mode.  This memory mode uses the most amount of memory in order to
 avoid using the hard drive as much as possible, which most often
 results in the fastest solution time.  This mode is recommended if
 enough physical memory is present to accommodate all of the solver
data.
