Reno Genest
Have a look at the LS-PrePost training:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/Training/Intro/
You can mesh this geometry using tet elements. Or, if you need hex elements, you will have to slice the geometry into sweepable bodies. There is more information in the training above.
Or, if you have access to Ansys Workbench, you can try using the Multizone meshing method in Mechanical to have hex mesh on this geometry. Or, you can use SpaceClaim to slice the geometry into sweepable bodies.
Reno.
