Hello Andrea,
I decided to apply Standard Earth Gravity to the wing. You can see how the Eco-Flex part of the wing sags by 13 mm at the trailing edge when there is no pressure in the wing.
When a pressure of 4.e-2 MPa is applied to the chamber on the top of the wing, the trailing edge goes down to 26 mm.
