GLUO
Hi @azaelmartinez84,
I just remember the variables in external circuit are only evaluated at the first time step. Your expression can be directly used for internal sources.
To realize this waveform in external circuit, there are two methods.
Method 1:  Use two VSin sources connect in series, both with (13800/sqrt(3))*(sqrt(2)) as amplitude (Va). The polarity of the second one is switched and Df =60. Please refer to the guide below.
Method 2:
Simply use VPWL instead of VSin. You could define your waveform as a dataset and import it.
GLUO
