georgia.stuart
Fluent:
Transcript Start Time:  15:44:09, 06 Sep 2022
Current Directory: "/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent"
Build Time: Nov 29 2021 12:13:18 EST
Executable Path: /opt/ohpc/pub/unpackaged/apps/ansys/solj-2022R1/v221/fluent/bin/fluent
ID    Hostname    Core   O.S.      PID        Vendor
n0-3  compute-15  4/192  Linux-64  6608-6611  Common KVM
host  compute-15         Linux-64  5910       Common KVM
MPI Option Selected: openmpi
Selected system interconnect: ethernet
Cortex Process ID: 5418
License Server Path: 1055@flex.utdallas.edu
Reading setting file in cache: "/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1.set"
Reading Settings file "/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1.set"...
Warning:
    Warning: The settings file being read was created in Fluent from a release prior to 2022 R1.
             Backward / forward compatibility is not guaranteed for such files.
             You must verify that all settings have been applied correctly.
Reading "/home/gks090020/Testfortitan1_files/dp0/FFF/MECH/FFF.1.msh"...
Buffering for file scan...
    2176 nodes, binary.
    2897 quadrilateral interior faces, zone  1, binary.
      37 quadrilateral wall faces, zone  5, binary.
      21 quadrilateral velocity-inlet faces, zone  6, binary.
      21 quadrilateral pressure-outlet faces, zone  7, binary.
    1992 triangular symmetry faces, zone  8, binary.
    1992 triangular symmetry faces, zone  9, binary.
      35 quadrilateral wall faces, zone 10, binary.
      68 quadrilateral wall faces, zone 11, binary.
    1992 wedge cells, zone  4, binary.
Warning: this is a double-precision solver.
Building...
     mesh
    auto partitioning mesh by Metis (fast),
    distributing mesh
        parts....,
        faces....,
        nodes....,
        cells....,
        bandwidth reduction using Reverse Cuthill-McKee: 505/29 = 17.4138
     materials,
     interface,
     domains,
    mixture
     zones,
    wall_cfd_coupled
    top_wall
    symmetry_2
    symmetry_1
    outlet
    inlet
    bottom_wall
    fluid
    interior-fluidSetting fluid (mixture) ... Done.
 Setting zone id of fluid to 4.
 Setting zone id of interior-fluid to 1.
 Setting zone id of bottom_wall to 5.
 Setting zone id of inlet to 6.
 Setting zone id of outlet to 7.
 Setting zone id of symmetry_1 to 8.
 Setting zone id of symmetry_2 to 9.
 Setting zone id of top_wall to 10.
 Setting zone id of wall_cfd_coupled to 11.
Done.
Setting interior-fluid (mixture) ... Done.
Setting bottom_wall (mixture) ... Done.
Setting inlet (mixture) ... Done.
Setting outlet (mixture) ... Done.
Setting symmetry_1 (mixture) ... Done.
Setting symmetry_2 (mixture) ... Done.
Setting top_wall (mixture) ... Done.
Setting wall_cfd_coupled (mixture) ... Done.
     parallel,
     dynamic zones,
        wall_cfd_coupled
        symmetry_2
        symmetry_1
Note: 3d, pressure-based, dynamic mesh, SST k-omega, transient case read into
      3d, double precision, pressure-based, dynamic mesh, SST k-omega, transient solver.
Done.
Grouping and repartitioning the fluid cell zones to be smoothed...
>> 4 Stored Partitions:
    P   Cells I-Cells Cell Ratio   Faces I-Faces Face Ratio Neighbors Load
    0     496      25      0.050    1770      25      0.014         2    1
    1     496      29      0.058    1772      29      0.016         2    1
    2     503      33      0.066    1797      33      0.018         3    1
    3     497      19      0.038    1777      19      0.011         1    1
   Collective Partition Statistics:        Minimum   Maximum   Total
   Cell count                              496       503       1992
   Mean cell count deviation               -0.4%     1.0%
   Partition boundary cell count           19        33        106
   Partition boundary cell count ratio     3.8%      6.6%      5.3%
   Face count                              1770      1797      7063
   Mean face count deviation               -0.5%     1.0%
   Partition boundary face count           19        33        53
   Partition boundary face count ratio     1.1%      1.8%      0.8%
   Partition neighbor count                1         3
   Partition Method                        Metis
   Stored Partition Count                  4
Done.
     1992 groups for partitioning (including overlaps)
     Merging groups across partitions:
      1 0
     Partition 1992 groups out of 1992 cells
Grouping and repartitioning the rest of fluid cell zones (if any)...
Migrating partitions to compute-nodes.
>> 4 Active Partitions:
    P   Cells I-Cells Cell Ratio   Faces I-Faces Face Ratio Neighbors Load  Ext Cells
    0     496      25      0.050    1770      25      0.014         2    1         25
    1     496      29      0.058    1772      29      0.016         2    1         29
    2     503      33      0.066    1797      33      0.018         3    1         33
    3     497      19      0.038    1777      19      0.011         1    1         19
Done.
Fast-loading "/opt/ohpc/pub/unpackaged/apps/ansys/solj-2022R1/v221/fluent/fluent22.1.0/addons/afd/lib/hdfio.bin"
Done.
Reading from compute-15:"/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1-1-00000.dat.h5" in NODE0 mode ...
  Reading results.
Parallel variables...
Done.
Writing to compute-15:"/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1-1-00000.cas.h5" in NODE0 mode and compression level 1 ...
  Writing mesh ...
        1992 cells,     1 zone  ...
        7063 faces,     8 zones ...
        2176 nodes,     1 zone  ...
  Done.
Done.
Writing to compute-15:"/home/gks090020/Testfortitan1_files/dp0/FFF/Fluent/FFF.1-1-00000.dat.h5" in NODE0 mode and compression level 1 ...
  Writing results.
Done.
 As physics coupling engine is no longer available. Disconnecting socket connection
Deleting Client...done
Shutting down Server...done
Error: Rpc Communication failure during SCAnalysis:GetRestartInitialStepIndex call at cortexmpc.c:912
Posting ANSYS Product Improvement Program performance data
Done.
Performance Timer for 0 iterations on 4 compute nodes
  Average wall-clock time per iteration:              0.000 sec
  Global reductions per iteration:                        0 ops
  Global reductions time per iteration:               0.000 sec (0.0%)
  Message count per iteration:                            0 messages
  Data transfer per iteration:                        0.000 MB
  LE solves per iteration:                                0 solves
  LE wall-clock time per iteration:                   0.000 sec (0.0%)
  LE global solves per iteration:                         0 solves
  LE global wall-clock time per iteration:            0.000 sec (0.0%)
  LE global matrix maximum size:                         0
  AMG cycles per iteration:                           0.000 cycles
  Relaxation sweeps per iteration:                        0 sweeps
  Relaxation exchanges per iteration:                     0 exchanges
  LE early protections (stall) per iteration:           0.000 times
  LE early protections (divergence) per iteration:      0.000 times
  Total SVARS touched:                              369
  Total wall-clock time:                              0.000 sec
Transcript Stop Time:  15:44:42, 06 Sep 2022
Total Transcript Time: 0 Minute 32 Second.
