georgia.stuart
Transient Structural:
 Ansys Mechanical Enterprise Academic Research
 |   W E L C O M E   T O   T H E   A N S Y S (R)  P R O G R A M     |
 *            ANSYS 2022 R1          LEGAL NOTICES             *
 * Copyright 1971-2022 ANSYS, Inc.  All rights reserved.       *
 * Unauthorized use, distribution or duplication is            *
 * prohibited.                                                 *
 * Ansys is a registered trademark of ANSYS, Inc. or its       *
 * subsidiaries in the United States or other countries.       *
 * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
 * documentation CD or online help for the complete Legal      *
 * Notice.                                                     *
 * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
 * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
 * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
 * The software products and documentation are furnished by    *
 * ANSYS, Inc. or its subsidiaries under a software license    *
 * agreement that contains provisions concerning               *
 * non-disclosure, copying, length and nature of use,          *
 * compliance with exporting laws, warranties, disclaimers,    *
 * limitations of liability, and remedies, and other           *
 * provisions.  The software products and documentation may be *
 * used, disclosed, transferred, or copied only in accordance  *
 * with the terms and conditions of that software license      *
 * agreement.                                                  *
 * ANSYS, Inc. is a UL registered                              *
 * ISO 9001:2015 company.                                      *
 * This product is subject to U.S. laws governing export and   *
 * re-export.                                                  *
 * For U.S. Government users, except as specifically granted   *
 * by the ANSYS, Inc. software license agreement, the use,     *
 * duplication, or disclosure by the United States Government  *
 * is subject to restrictions stated in the ANSYS, Inc.        *
 * software license agreement and FAR 12.212 (for non-DOD      *
 * licenses).                                                  *
 2022 R1
 Point Releases and Patches installed:
 Ansys, Inc. License Manager 2022 R1
 Ansys, Inc. Products 2022 R1
 Autodyn 2022 R1
 LS-DYNA 2022 R1
 CFX (includes CFD-Post) 2022 R1
 Chemkin 2022 R1
 EnSight 2022 R1
 FENSAP-ICE 2022 R1
 Fluent (includes CFD-Post) 2022 R1
 Polyflow (includes CFD-Post) 2022 R1
 Forte (includes EnSight) 2022 R1
 TurboGrid 2022 R1
 ICEM CFD 2022 R1
 Aqwa 2022 R1
 Mechanical Products 2022 R1
 Icepak (includes CFD-Post) 2022 R1
 ACIS Geometry Interface 2022 R1
 Catia, Version 5 Geometry Interface 2022 R1
 Parasolid Geometry Interface 2022 R1
          *****  ANSYS COMMAND LINE ARGUMENTS  *****
  BATCH MODE REQUESTED (-b)    = NOLIST
  INPUT FILE COPY MODE (-c)    = COPY
  DISTRIBUTED MEMORY PARALLEL REQUESTED
       4 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
    TOTAL OF     4 CORES REQUESTED
  MPI OPTION                   = OPENMPI
  INPUT FILE NAME              = /home/gks090020/_ProjectScratch/ScrF00E/dummy.dat
  OUTPUT FILE NAME             = /home/gks090020/_ProjectScratch/ScrF00E/solve.out
  START-UP FILE MODE           = NOREAD
  STOP FILE MODE               = NOREAD
  CONNECTION TO COUPLING SERVER REQUESTED
    SYSTEM NAME                = Solution 1
    HOST NAME                  = compute-15
    SERVER PORT REQUESTED      = 58765
 RELEASE= 2022 R1              BUILD= 22.1      UP20211129   VERSION=LINUX x64
 CURRENT JOBNAME=file0  15:43:43  SEP 06, 2022 CP=      0.358
MAPDL is connecting to the system coupling service on compute-15 through port  58765 ...
   ... connected
 PARAMETER _DS_PROGRESS =     999.0000000
 /INPUT FILE= ds.dat  LINE=       0
 *** NOTE ***                            CP =       0.528   TIME= 15:44:08
 The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
 solution.  Command is ignored.
 *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  15.7355556
 TITLE=
 Testfortitan1--Transient (B5)
  ACT Extensions:
      LSDYNA, 2021.1
      5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
 SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
  TYPE=STRI  DIMENSIONS=      248        1        1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = /home/gks090020/_ProjectScratch/ScrF00E/
 SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = /home/gks090020/Testfortitan1_files/dp0/SYS/MECH/
 SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = /home/gks090020/Testfortitan1_files/user_files/
 --- Data in consistent NMM units. See Solving Units in the help system for more
 MPA UNITS SPECIFIED FOR INTERNAL
  LENGTH      = MILLIMETERS (mm)
  MASS        = TONNE (Mg)
  TIME        = SECONDS (sec)
  TEMPERATURE = CELSIUS (C)
  TOFFSET     = 273.0
  FORCE       = NEWTON (N)
  HEAT        = MILLIJOULES (mJ)
 INPUT  UNITS ARE ALSO SET TO MPA
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 2022 R1          22.1     ***
 DISTRIBUTED Ansys Mechanical Enterprise Academic Research
 00000000  VERSION=LINUX x64     15:44:08  SEP 06, 2022 CP=      0.539
          ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "fea" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Set Reference Temperature ***********
 *********** Send Materials ***********
 *********** Send Named Selection as Node Component ***********
 *********** Send Named Selection as Element Component ***********
 *********** Fixed Supports ***********
 ********* Frictionless Supports Z *********
 *********** Create FSI Flags ***********
 ***** ROUTINE COMPLETED *****  CP =         1.095
 --- Number of total nodes = 1412
 --- Number of contact elements = 0
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 162
 --- Number of condensed parts = 0
 --- Number of total elements = 162
 *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  15.7355556
 *************************    SOLUTION       ********************************
 *****  ANSYS SOLUTION ROUTINE  *****
 PERFORM A TRANSIENT ANALYSIS
  THIS WILL BE A NEW ANALYSIS
 LARGE DEFORMATION ANALYSIS
 STEP BOUNDARY CONDITION KEY= 1
 PARAMETER _THICKRATIO =     0.000000000
 USE SPARSE MATRIX DIRECT SOLVER
 CONTACT INFORMATION PRINTOUT LEVEL       1
 SUPPRESS THE FOLLOWING ITEMS FROM BEING WRITTEN TO THE RESULTS FILE:
  NONE
 DO NOT COMBINE ELEMENT MATRIX FILES (.emat) AFTER DISTRIBUTED PARALLEL SOLUTION
 DO NOT COMBINE ELEMENT SAVE DATA FILES (.esav) AFTER DISTRIBUTED PARALLEL SOLUTION
 WRITE ALL COMPONENTS TO THE COMPONENTS FILE.
 START WRITING AT THE BEGINNING OF FILE file.cm
 COMPONENTS WERE WRITTEN TO FILE= file.cm
 PERFORM A FULL TRANSIENT ANALYSIS
  USING HHT ALGORITHM
 USE SETTINGS FOR MODERATE SPEED DYNAMIC APPLICATIONS
 SECOND ORDER TRANSIENT PARAMETERS
   GAMMA= 0.1000      (ALPHA= 0.3025      DELTA= 0.6000      ALPHAF= 0.1000      ALPHAM=  0.000    )
 USE FIRST ORDER TRANSIENT PARAMETER THETA=  1.000
 NLDIAG: Nonlinear diagnostics CONT option is set to ON.
         Writing frequency : each ITERATION.
 A NEGATIVE FILM COEFFICIENT IS USED AS IS.
 The variables will be mapped with the default mesh shape in the System Coupling.
 DEFINE RESTART CONTROL FOR LOADSTEP ALL
 AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS   -1
 DELETE RESTART FILES OF ENDSTEP
 ******************* SOLVE FOR LS 1 OF 1 ****************
 PRINTOUT RESUMED BY /GOP
 DO NOT USE AUTOMATIC TIME STEPPING THIS LOAD STEP
 USE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
 FOR AUTOMATIC TIME STEPPING:
   USE      1 SUBSTEPS AS A MAXIMUM
   USE      1 SUBSTEPS AS A MINIMUM
 TIME=  1.0000
 INCLUDE TRANSIENT EFFECTS FOR  ALL DEGREES OF FREEDOM THIS LOAD STEP
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
   FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE ETMP ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE SRFS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE BKST ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE NLDA ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE V    ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE A    ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 NONLINEAR STABILIZATION CONTROL:
 KEY=OFF
 *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000
 *IF  ANSINTER_                         ( =   0.00000     )  NE
      0                                 ( =   0.00000     )  THEN
 *ENDIF
 *** NOTE ***                            CP =       1.179   TIME= 15:44:08
 The automatic domain decomposition logic has selected the MESH domain
 decomposition method with 4 processes per solution.
 *****  ANSYS SOLVE    COMMAND  *****
 *** WARNING ***                         CP =       1.181   TIME= 15:44:08
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** NOTE ***                            CP =       1.182   TIME= 15:44:09
 The model data was checked and warning messages were found.
  Please review output or errors file (
 /home/gks090020/_ProjectScratch/ScrF00E/file0.err ) for these warning
 messages.
 *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
      --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
 ELEMENT TYPE         1 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
  KEYOPT(1-12)=    0    0    0    0    0    0    0    0    0    0    0    0
 00000000  VERSION=LINUX x64     15:44:09  SEP 06, 2022 CP=      1.184
                       S O L U T I O N   O P T I O N S
   PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
   DEGREES OF FREEDOM. . . . . . UX   UY   UZ
   ANALYSIS TYPE . . . . . . . . . . . . . . . . .TRANSIENT
      SOLUTION METHOD. . . . . . . . . . . . . . .FULL
   OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
   NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
   EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
   NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
   GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
   USE SYSTEM COUPLING . . . . . . . . . . . . . .YES
 *** NOTE ***                            CP =       1.186   TIME= 15:44:09
 This nonlinear analysis defaults to using the full Newton-Raphson
 solution procedure.  This can be modified using the NROPT command.
 The conditions for direct assembly have been met.  No .emat or .erot
 files will be produced.
     D I S T R I B U T E D   D O M A I N   D E C O M P O S E R
  ...Number of elements: 162
  ...Number of nodes:    1412
  ...Decompose to 4 CPU domains
  ...Element load balance ratio =     1.050
 SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
 *** DATA TRANSFER INFORMATION ON SOURCE SIDE ***
     SOLVER . . . . . . . . . . . . . . . . . .Transient Structural (Solution 1)
      REGION. . . . . . . . . . . . . . . . . .Fluid Solid Interface (FSIN_1)
      VARIABLE. . . . . . . . . . . . . . . . .Incremental_Displacement (INCD)
 *** DATA TRANSFER INFORMATION ON TARGET SIDE ***
      VARIABLE. . . . . . . . . . . . . . . . .Force (FORC)
 *** LIST MESH INFORMATION ON FSIN/FVIN INTERFACES
     REGION. . . . . . . . . . . . . . . . . .       1
      NUMBER OF ELEMENTS . . . . . . . . . . .     107
      NUMBER OF NODES. . . . . . . . . . . . .     538
      NUMBER OF CORNER NODES . . . . . . . . .     216
 *** ERROR ***                           CP =       1.867   TIME= 15:44:42
 A System Coupling error occurred while the request AssignToken was
 being served.
 NUMBER OF WARNING MESSAGES ENCOUNTERED=          1
 NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
+--------- D I S T R I B U T E D   A N S Y S   S T A T I S T I C S ------------+
Release: 2022 R1            Build: 22.1       Update: UP20211129   Platform: LINUX x64
Date Run: 09/06/2022   Time: 15:44     Process ID: 6375
Operating System: CentOS Linux release 8.3.2011
Processor Model: Common KVM processor
Compiler: Intel(R) Fortran Compiler Version 19.0.0  (Build: 20190206)
          Intel(R) C/C++ Compiler Version 19.0.0  (Build: 20190206)
          Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191122
          BLAS Library supplied by Intel(R) MKL
Number of machines requested            :    1
Total number of cores available         :  192
Number of physical cores available      :  192
Number of processes requested           :    4
Number of threads per process requested :    1
Total number of cores requested         :    4 (Distributed Memory Parallel)
MPI Type: OPENMPI
MPI Version: Open MPI v4.0.5
GPU Acceleration: Not Requested
Job Name: file0
Input File: dummy.dat
  Core                Machine Name   Working Directory
     0                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
     1                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
     2                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
     3                  compute-15   /home/gks090020/_ProjectScratch/ScrF00E
Latency time from master to core     1 =    5.073 microseconds
Latency time from master to core     2 =    5.088 microseconds
Latency time from master to core     3 =    4.623 microseconds
Communication speed from master to core     1 =  3351.41 MB/sec
Communication speed from master to core     2 =  3427.78 MB/sec
Communication speed from master to core     3 =  3425.69 MB/sec
Total CPU time for main thread                    :        1.8 seconds
Total CPU time summed for all threads             :        1.9 seconds
Elapsed time spent obtaining a license            :        0.7 seconds
Elapsed time spent pre-processing model (/PREP7)  :        0.2 seconds
Elapsed time spent solution - preprocessing       :        0.5 seconds
Elapsed time spent computing solution             :       31.7 seconds
Elapsed time spent solution - postprocessing      :        0.0 seconds
Elapsed time spent post-processing model (/POST1) :        0.0 seconds
Equation solver used                              :            Sparse (symmetric)
Sum of memory used on all processes               :       28.0 MB
Sum of memory allocated on all processes          :     5184.0 MB
Physical memory available                         :        344 GB
Total amount of I/O written to disk               :        0.0 GB
Total amount of I/O read from disk                :        0.0 GB
+------ E N D   D I S T R I B U T E D   A N S Y S   S T A T I S T I C S -------+
 |                       DISTRIBUTED ANSYS RUN COMPLETED                     |
 | Ansys 2022 R1               Build 22.1         UP20211129     LINUX x64   |
 | Database Requested(-db)  1024 MB    Scratch Memory Requested      1024 MB |
 | Maximum Database Used       1 MB    Maximum Scratch Memory Used      6 MB |
 |        CP Time      (sec) =          1.920       Time  =  15:44:42        |
 |        Elapsed Time (sec) =         61.000       Date  =  09/06/2022      |
