Cheta Rathod
Yes, the bearing element combi214 is 2D and used for lateral rotordynamic studies where the stiffnesses are in the plane perpendicular to the axial.
In your case, we can use a spring/damper to represent Thurst bearing. You may use a general joint with the axial DOF set to free and add a stiffness value in the axial direction. Or use a bushing bushing element as convenient.
