DrAmine
You can create UDF's to get maximum temperature or mean temperature over all particles (from Lagrangian side) and create then an output parameter for that.
If you want to avoid that, you can enable Mean Values under DPM Panel and you can access the DPM Mean Temperature as Eulerian Side variable which you can then use like other eulerian variable to do with it whatever you want.
