Naresh Patre
Hello @fkorkmaz,
In the image that you shared, I can see several assembly conditions defined. I am not sure if they would be interfering with the tangent assembly that you are tryng to define. I guess you are trying to define the tangent condition on the cylindfircal surface bodies. If yes, is it possible to move those bodies to separate components and then try defining tangent condition?
- Naresh Patre
