Weird. And as you have the interface pairs it's not like you have the same face on both sides of the set up.  Changing the rotating domain size isn't recommended as the gap should mean there's little/no overlap.
If you recreate the interface so you have many to many faces on each side? I assume the cylinder isn't distorted in any way? Why the odd tet region?
