Nikhil Narale
Are you using Aspect Ratio Offset method? If so, the BL mesh may be squizzing down at the trailing edge to maintain the aspect ratio of the first cell and consequently other cells, as the surface mesh size at the trailing edge may be refined (small). Can you try using the 'Uniform' offset method?
Nikhil
