Guilin Sun
In principle you can change the source. Since it has phase compensation, you may need to modify the script to meet your requirement.
Currently this analysis group uses ONE field component to be the S parameter. You will need to justify if this is correct for a dipole, as the dipole radiates differently from the plane wave source.
