Yu Bi
CONV means converge. This error still means the cable you set failed to converge during calculation. The reason the error shows is that the rotation in normal direction between the nodes of the cable is too large in a time step. You can try to decrease your time interval for the analysis and also have a check if cable's properties have been set properly.
