Zhihao Liu
Oh wow, that is the issue. The License manager is able to run with no problem. However, when I tried to run Ansys Fluent. It is still giving me errors.
-------------------------------------------- NORMAL STARTUP 2022/11/01 08:25:17 --------------------------------------------- Ansys Licensing Interconnect version 2022.2.0 (20220519) for winx64. Updated at Ansys Release 2022 R2. Started on 2022/11/01 08:25:17 by SYSTEM@DESKTOP-TCV3QIV:winx64 with pid 21344. (C) 2022 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited. Built Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6 Built Using OpenSSL 1.1.1n 15 Mar 2022 ----------------------------------------------------------------------------------------------------------------------------- Please note that entries in this debug log have the following format: TIMESTAMP ACTION FEATURE REVISION (BUILD DATE) A/B/C/D W/X/Y/Z PID:MPID:APP:USER@HOST:PLATFORM:DISPLAY SOCKET:IP Licenses statistics: -------------------- A is the number of licenses requested by this ACTION. B is the number of licenses used by this USER. C is the number of licenses used by all users. D is the number of licenses available in the local license pool. License server performance statistics: -------------------------------------- W is the number of currently connected client applications. X is the maximum number of connected client applications. Y is the unique serial number of this client application. Z is the number of all client applications served by this Licensing Interconnect server. ----------------------------------------------------------------------------------------------------------------------------- 2022/11/01 08:25:17 INFO ANSYSLI_CMD=E:\Ansys\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_server.exe -nodaemon 2022/11/01 08:25:17 INFO ANSYSLI_INITIALIZATION_FILE='E:\Ansys\ANSYS Inc\Shared Files\Licensing\ansyslmd.ini' 2022/11/01 08:25:17 INFO ANSYSLI_MONITOR=E:\Ansys\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_monitor.exe 2022/11/01 08:25:17 INFO ANSYSLI_PRODORD_FILE='E:\Ansys\ANSYS Inc\Shared Files\Licensing\prodord\ansysli.prodord.xml' 2022/11/01 08:25:18 INFO FLEXLM_LICENSE_FILE='E:\Ansys\ANSYS Inc\Shared Files\Licensing\license_files' 2022/11/01 08:25:18 INFO ANSYSLI_PORT=2325 2022/11/01 08:25:18 INFO Listen Socket Created 2022/11/01 08:25:18 INFO Backing up FLEXlm debug log file to E:\Ansys\ANSYS Inc\Shared Files\Licensing\logs_backup\license_20221101_082518.log. 2022/11/01 08:25:18 INFO E:\Ansys\ANSYS Inc\Shared Files\Licensing\winx64\lmgrd.exe -c "E:\Ansys\ANSYS Inc\Shared Files\Licensing\license_files" -l "E:\Ansys\ANSYS Inc\Shared Files\Licensing\license.log" 2022/11/01 08:25:19 INFO Started FLEXlm server. 2022/11/01 08:25:25 CACHE_SERVER Available licenses from file E:\Ansys\ANSYS Inc\Shared Files\Licensing\license_files: 1 1spacdes 1 a_jt_reader 3 a_spaceclaim_dirmod 1 a_spaceclaim_faceteddata 1 acdi_adprepost 1 acfd_vki 1 acfx_bldmdlr 1 acfx_pre 1 acpreppost 1 advanced_meshing 1 afsp_gui 1 afsp_optigrid 1 afsp_viewmerical 1 agppi 2 alinks_gui 1 am_module 1 am_prep 1 am_print 1 ans_act 36 anshpc 1 ansrom 1 ansys 1 aqwa_pre 1 aqwa_solve 1 cfd_base 1 cfd_polyflow_ui 1 cfd_preppost 1 cfd_preppost_pro 1 cfd_solve_level1 1 cfd_solve_level2 1 cfd_solve_level3 1 disco_level1 1 disco_level2 1 dsdxm 1 dyna 3 dynardo_osl 3 dynardo_osp 15 dysmp 2 elec_filter 3 elec_solve_2d 1 elec_solve_hfss 3 elec_solve_icepak 3 elec_solve_level1 3 elec_solve_level2 2 elec_solve_level3 1 elec_solve_maxwell 2 elec_solve_q3d 2 elec_solve_siwave 3 electronics2d_gui 3 electronics3d_gui 3 electronics_desktop 3 electronicsckt_gui 1 ema_charge_gui 1 ema_charge_solve 1 ema_gui 1 ema_solve 1 emag 1 ensight_enterprise 1 envision_pro 1 explicit_advanced 1 explicit_basic 1 fluent_meshing 1 fluent_meshing_pro 1 fluent_setup_post 1 fluent_setup_post_pro 1 forming_level1 1 forming_level2 1 forte_3 1 granta_selector 3 granta_sim_mat_data 1 ice_translator 1 mat_designer 2 medini_base 2 medini_connectivity 2 medini_cybersec_level1 2 medini_cybersec_level2 2 medini_dc_configurator 2 medini_safety_level1 2 medini_safety_level2 2 medini_safety_level3 1 motorcad 1 motorcad_im 1 motorcad_pm 1 motorcad_sync 3 optislang_level1 3 optislang_level2 3 optislang_level3 2 pemag 2 pexprt 1 piautoin 1 picatv5 1 piproe 1 pisoledg 1 pisolwor 1 piug 1 preppost 1 rd_ckcompute 1 rd_ckgraph 1 rd_ckpost 1 rd_ckpreproc 1 rd_ckui 1 rd_fortemesh 1 rd_forteui 1 rd_forteviz 1 rd_kineticsapi 1 rd_mechforte 1 rd_mechmfc 1 rd_mechsoot 1 rd_mechwb 1 rd_reactionwbui 1 rdacis 3 rdpara 1 sherlock 1 simplorer_advanced 1 simplorer_control 1 simplorer_cprogrinterface 1 simplorer_gui 2 simplorer_libsmps 1 simplorer_sim 1 simplorer_sim_entry 1 simplorer_vhdlams 1 vmotion 1 vmotion_catiai 1 vmotion_drtrain 1 vmotion_drtrain_pre 1 vmotion_links 1 vmotion_mesh 1 vmotion_mesh_pre 1 vmotion_para 1 vmotion_post 1 vmotion_pre 1 vmotion_step 2022/11/01 08:25:25 CACHE_SERVER No active FLEXlm options. 2022/11/01 08:25:25 CACHE_SERVER No active Ansys Licensing Interconnect options. 2022/11/01 08:25:25 INFO Ready to accept connections
8:25:18 (lmgrd) ----------------------------------------------- 8:25:18 (lmgrd) Please Note: 8:25:18 (lmgrd) 8:25:18 (lmgrd) This log is intended for debug purposes only. 8:25:18 (lmgrd) In order to capture accurate license 8:25:18 (lmgrd) usage data into an organized repository, 8:25:18 (lmgrd) please enable report logging. Use Flexera's 8:25:18 (lmgrd) software license administration solution, 8:25:18 (lmgrd) FlexNet Manager, to readily gain visibility 8:25:18 (lmgrd) into license usage data and to create 8:25:18 (lmgrd) insightful reports on critical information like 8:25:18 (lmgrd) license availability and usage. FlexNet Manager 8:25:18 (lmgrd) can be fully automated to run these reports on 8:25:18 (lmgrd) schedule and can be used to track license 8:25:18 (lmgrd) servers and usage across a heterogeneous 8:25:18 (lmgrd) network of servers including Windows NT, Linux 8:25:18 (lmgrd) and UNIX. 8:25:18 (lmgrd) 8:25:18 (lmgrd) ----------------------------------------------- 8:25:18 (lmgrd) 8:25:18 (lmgrd) 8:25:18 (lmgrd) Server's System Date and Time: Tue Nov 01 2022 08:25:18 Pacific Daylight Time 8:25:18 (lmgrd) pid 23012 8:25:18 (lmgrd) SLOG: Summary LOG statistics is enabled. 8:25:18 (lmgrd) Done rereading 8:25:18 (lmgrd) FlexNet Licensing (v11.19.0.0 build 284597 x64_n6) started on DESKTOP-TCV3QIV (IBM PC) (11/1/2022) 8:25:18 (lmgrd) Copyright (c) 1988-2022 Flexera. All Rights Reserved. 8:25:18 (lmgrd) World Wide Web: http://www.flexerasoftware.com 8:25:18 (lmgrd) License file(s): E:\Ansys\ANSYS Inc\Shared Files\Licensing\license_files\ansyslmd.lic 8:25:18 (lmgrd) lmgrd tcp-port 1055 8:25:18 (lmgrd) (@lmgrd-SLOG@) =============================================== 8:25:18 (lmgrd) (@lmgrd-SLOG@) === LMGRD === 8:25:18 (lmgrd) (@lmgrd-SLOG@) Start-Date: Tue Nov 01 2022 08:25:18 Pacific Daylight Time 8:25:18 (lmgrd) (@lmgrd-SLOG@) PID: 23012 8:25:18 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.19.0.0 build 284597 x64_n6 ( build 284597 (ipv6)) 8:25:18 (lmgrd) (@lmgrd-SLOG@) 8:25:18 (lmgrd) (@lmgrd-SLOG@) === Network Info === 8:25:18 (lmgrd) (@lmgrd-SLOG@) Listening port: 1055 8:25:18 (lmgrd) (@lmgrd-SLOG@) 8:25:18 (lmgrd) (@lmgrd-SLOG@) === Startup Info === 8:25:18 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: No 8:25:18 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server 8:25:18 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c E:\Ansys\ANSYS Inc\Shared Files\Licensing\license_files -l E:\Ansys\ANSYS Inc\Shared Files\Licensing\license.log 8:25:18 (lmgrd) (@lmgrd-SLOG@) License file(s) used: E:\Ansys\ANSYS Inc\Shared Files\Licensing\license_files\ansyslmd.lic 8:25:18 (lmgrd) (@lmgrd-SLOG@) =============================================== 8:25:18 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-40000 8:25:18 (lmgrd) Starting vendor daemons ... 8:25:18 (lmgrd) Started ansyslmd (pid 19984) 8:25:18 (ansyslmd) SLOG: Summary LOG statistics is enabled. 8:25:18 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT1 8:25:18 (ansyslmd) SLOG: VM Status: 255 8:25:18 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT5 8:25:18 (ansyslmd) SLOG: TPM Status: 2 8:25:18 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT6 8:25:18 (ansyslmd) Server started on DESKTOP-TCV3QIV for: 1spacdes 8:25:18 (ansyslmd) a_jt_reader a_spaceclaim_dirmod a_spaceclaim_faceteddata 8:25:18 (ansyslmd) acdi_adprepost acfd_vki acfx_bldmdlr 8:25:18 (ansyslmd) acfx_pre acpreppost advanced_meshing 8:25:18 (ansyslmd) afsp_gui afsp_optigrid afsp_viewmerical 8:25:18 (ansyslmd) agppi am_module am_prep 8:25:18 (ansyslmd) am_print ans_act anshpc 8:25:18 (ansyslmd) ansrom ansys aqwa_pre 8:25:18 (ansyslmd) aqwa_solve cfd_base cfd_polyflow_ui 8:25:18 (ansyslmd) cfd_preppost cfd_preppost_pro cfd_solve_level1 8:25:18 (ansyslmd) cfd_solve_level2 cfd_solve_level3 disco_level1 8:25:18 (ansyslmd) disco_level2 dsdxm dyna 8:25:18 (ansyslmd) dynardo_osl dynardo_osp dysmp 8:25:18 (ansyslmd) elec_solve_2d elec_solve_icepak elec_solve_level1 8:25:18 (ansyslmd) elec_solve_level2 electronics_desktop electronics2d_gui 8:25:18 (ansyslmd) electronics3d_gui electronicsckt_gui emag 8:25:18 (ansyslmd) ensight_enterprise envision_pro explicit_advanced 8:25:18 (ansyslmd) explicit_basic fluent_meshing fluent_meshing_pro 8:25:18 (ansyslmd) fluent_setup_post fluent_setup_post_pro forming_level1 8:25:18 (ansyslmd) forming_level2 forte_3 granta_sim_mat_data 8:25:18 (ansyslmd) ice_translator mat_designer optislang_level1 8:25:18 (ansyslmd) optislang_level2 optislang_level3 pemag 8:25:18 (ansyslmd) pexprt piautoin picatv5 8:25:18 (ansyslmd) piproe pisoledg pisolwor 8:25:18 (ansyslmd) piug preppost rd_ckcompute 8:25:18 (ansyslmd) rd_ckgraph rd_ckpost rd_ckpreproc 8:25:18 (ansyslmd) rd_ckui rd_fortemesh rd_forteui 8:25:18 (ansyslmd) rd_forteviz rd_kineticsapi rd_mechforte 8:25:18 (ansyslmd) rd_mechmfc rd_mechsoot rd_mechwb 8:25:18 (ansyslmd) rd_reactionwbui rdacis rdpara 8:25:18 (ansyslmd) sherlock simplorer_LibSMPS vmotion 8:25:18 (ansyslmd) vmotion_catiai vmotion_drtrain vmotion_drtrain_pre 8:25:18 (ansyslmd) vmotion_links vmotion_mesh vmotion_mesh_pre 8:25:18 (ansyslmd) vmotion_para vmotion_post vmotion_pre 8:25:18 (ansyslmd) vmotion_step granta_selector alinks_gui 8:25:18 (ansyslmd) elec_filter elec_solve_level3 elec_solve_maxwell 8:25:18 (ansyslmd) elec_solve_q3d elec_solve_siwave medini_base 8:25:18 (ansyslmd) medini_connectivity medini_cybersec_level1 medini_cybersec_level2 8:25:18 (ansyslmd) medini_dc_configurator medini_safety_level1 medini_safety_level2 8:25:18 (ansyslmd) medini_safety_level3 motorcad motorcad_im 8:25:18 (ansyslmd) motorcad_pm motorcad_sync simplorer_advanced 8:25:18 (ansyslmd) simplorer_control simplorer_CProgrInterface simplorer_gui 8:25:18 (ansyslmd) simplorer_sim simplorer_sim_entry simplorer_vhdlams 8:25:18 (ansyslmd) elec_solve_hfss ema_charge_gui ema_charge_solve 8:25:18 (ansyslmd) ema_gui ema_solve 8:25:18 (ansyslmd) EXTERNAL FILTERS are OFF 8:25:18 (lmgrd) ansyslmd using TCP-port 55644 8:25:18 (ansyslmd) Serving features for the following vendor names: ansyslmd ansoftd hclmd apacheda DYNARDO 8:25:18 (ansyslmd) SLOG: Statistics Log Frequency is 240 minute(s). 8:25:18 (ansyslmd) SLOG: TS update poll interval is 600 seconds. 8:25:18 (ansyslmd) SLOG: Activation borrow reclaim percentage is 0. 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) =============================================== 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) === Vendor Daemon === 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Vendor daemon: ansyslmd 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Start-Date: Tue Nov 01 2022 08:25:18 Pacific Daylight Time 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) PID: 19984 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) VD Version: v11.19.0.0 build 284597 x64_n6 ( build 284597 (ipv6)) 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) === Startup/Restart Info === 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Options file used: None 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Is vendor daemon a CVD: Yes 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Is FlexNet Licensing Service installed and compatible: No 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) FlexNet Licensing Service Version: 11.16.5.0 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Is TS accessed: No 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) TS access time: -NA- 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Number of VD restarts since LS startup: 0 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) === Network Info === 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Listening port: 55644 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Daemon select timeout (in seconds): 1 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) === Host Info === 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Host used in license file: DESKTOP-TCV3QIV 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) HostID node-locked in license file: DISK_SERIAL_NUM=3c4bd81a 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) HostID of the License Server: "001a7dda7113 e4e420524153 e4e420524153 e4e420524153 be17b8b5ea23 bc17b8b5ea24 18c04ddbfa2d bc17b8b5ea23" 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) Running on Hypervisor: None (Physical) 8:25:18 (ansyslmd) (@ansyslmd-SLOG@) =============================================== 8:25:18 (ansyslmd) Ecomms: Encrypted Communication disabled 8:25:18 (ansyslmd) TCP_NODELAY NOT enabled 8:25:18 (ansyslmd) Listener Thread: running
