Nikhil Narale
Yes, set the 'Ignore boundary layers at acute angles' option to no, and try aspect ratio. Ideally, it should work then. Otherwise, reduce the maximum surface mesh size on the wing/airfoil to a lower value and try again.
In fact, it looks like except the 'last-ratio', the rest of the methods should work for you.
