November 3, 2022 at 12:15 pm
Do you mean with the first sentence to pic Fluid for the contours rather than Internal? (I don’t know why there is such high velocity under the bridge slab deck)
In this case I am not considering the supports as I am analysing middle span sections. (The four thin small lines below the deck are steel girders).
Does Fluent consider buoyancy?
Then, Residuals & reports are like this even though is a steady state?
