DrAmine
I just wrote that I do not understand from your screnshots where the gas inlet and liquid inlet  are located.
Again use unsteady solver and I assume you need to start there from air filled oven.
You can at first check if VOF or Mixture Model are sufficient to deal with it (I do not think that is the best set but you can do your first assessment).
