javat33489
Thanks a lot for the answers!
>>A1: It is not possible to share or connect the nodes of a SOLID body with the nodes of a SURFACE or LINE body. This must be done with Contact Elements.
Q1. Sorry, I didn't write exactly. When I wrote CONNECT, I meant how to connect using CONTACT.
I have dealt with this issue. You can use a joint, in which you specify the node of the beam and the face of the solid, so they will have contact.
>>A2: It is not possible to share or connect the nodes of a LINE body that is parallel to another LINE body. This must be done with Contact Elements
Q2. How to use contact? You cannot specify many nodes in a contact or joint. I was able to highlight all the nodes of both beams, where they have a common place.
>>A5: SHARE means it will combine the beam endpoints to connect the mesh.
Any sort of sharing of nodes is done in a Part group.
Q5. Means it is necessary not to unite them in one group if SHARE is used?
>>In practice, it is not always practical to decompose a 3D solid geometry into LINE and SURFACE bodes.
I need this to make it easier. Otherwise, my PC cannot solve this problem. The model is very massive.
