Rizvi Arefin Rinik
problem solved as i used shear topology......but i dont undestand the reason .....in some cases using boolean substract this types of issue can be resolved...but this time it didnt work...any way thank you.....but using shear topology is there will any effect on solver?? as from fluid heat transfer will take place into the shell.
