pv00170
Yeah I get the solver doesnt know the mass of the bridge, but knows the volume of displaced water, and I imagine it solves buoyancy by using it. I assume there is no direct method to check wich % of the total pressure are due to water weight, buoyancy and hydrodynamic.
With "If you look there are also forces (x, y & z) as opposed to lift & drag" do you mean negative values?
