Guilin Sun
The main problem I guess is, the Gaussian beam cannot efficiently propagate in such PhC waveguide. Usually you will need to use a regular straight waveguide to excite a certain mode, and use regular output straight waveguide to measure results. Otherwise a plane mode is not proper to exsit a Bloch mode. similarly the monitor result will also depends on its location.
