pv00170
I will use 2D CFD results in a 3D FE analysis in which bridge has mass. Then, I will check if drag and lift forces can move the bridge.
Do CFD results vary depending on the mass of the bridge? How can this mislead the results? (Could you explain more, since maybe there is something I am missing)
