jscsgh
Dear Rob,
Many thanks for your reply. I just tried once again. It seems that when exporting cell data, the results seem OK. However, when I switched to node data, 0 value start to appear.
Could you please expand the explanation on "use a journal to read & export ASCII in serial afterwards". I am using GUI, dose it mean that first I run the whole simulation and save the .data file for each time step in parallel. And afterwards I load each .data seperately in serial then export ASCII data.
Or, you mean something else by "use a journal to read & export ASCII in serial afterwards".
Again, many thanks for your time!
Best regards
