Mike Rife
Hi vravinar
You may want to post the second question separately.  These are two very different topics.
For the first question what was the name of the table?  If a "_" was used then the UI will not show the table if the name had a leading "_".  Don't use a leading underscore as this style is usually reserved for internal parameter names.
Mike
