vildemarireinertsen
Thank you for the answer. I will just add this for reference in case somone else has the same problem. I had another look at the "check memory estimation"-part and, to me, it seems like the new version treats disabled monitors etc as enabled because I could se them in the detailed list in the memory estimation and the memory estimation decreased when I deleted monitors that I had set as disabled. The large amount of memory required came from the disabled monitors which where index and advanced absorption monitors.
