Felix Kalscheuer
Thank you a lot for your reply peteroznewman,
Please consider the following:
- I have tuned the model a lot. The average simulation time per Deisgn Point was 11.3 seconds.
- If have created and run a DOE as custom with all 8228 Points.
Accordingly the DOE is already finished. What I am wondering about is: How can I make the Response Surface respect the measured Design Points and have it only interpolate points that lie between these Design Points?
Ideally I would like to have 2 additional points between each Design Point, with equal distances between them.
As I can also export the measurements into an Excell document, I could also use a third party programm to do this. Ideas are highly appreciated.
