Mepal
Thank you so much Rob for your reply.
My work has two phases.
In the first phase, I need to create a stable packed-bed (that cannot move) inside a small chamber. Then I will fill a solution into its porous region to notice the movement of the solution.
In the second phase, I will create a group of particles (that can move) inside a small chamber to notice its interaction with an external force.
