Reno Genest
I  checked with Kai and for method 1, there should be a joint_set.k file that comes with the THUMS model. This file has the *SET_NODE of COG of the join along with *SET_PART for each joint (left_shoulder, etc.). Maybe you can check with Toyota and see if you can get  the joint file. It looks like the following:
$# LS-DYNA Keyword file created by LS-PrePost 4.0 (Alpha) - 27Mar2012(03:20)
$# Created on Apr-05-2012 (16:04:40)
$thums all joint parts set.
$thums all COG node set
*KEYWORD
*SET_NODE_LIST_TITLE
thums_hpoint_id
900000
99610200
$begin left shoulder joint info
left_shoulder_COG
900001
86006085
*SET_PART_LIST_TITLE
Left_Shoulder_joint_Deformable_part
100001
89100600,89100700,89200700,89200701,89200702
Left_Shoulder_joint_Distal_part
    100002     0.000     0.000     0.000     0.000MECH
86000000,86000100,86000101,86000102,86000200,86000300,86000301,86000302
86000400,86000500,86000501,86000502,86000600,86000601,86000700,86000701
86000800,86000801,86000900,86000901,86001000,86001001,86001100,86001101
86001200,86001201,86001300,86001301,86001400,86001401,86001500,86001501
86001600,86001601,86001700,86001701,86001800,86001801,86001900,86001901
86002000,86002001,86002100,86002101,86002200,86002201,86002300,86002301
86002400,86002401,86002500,86002501,86002600,86002601,86002700,86002701
86002800,86002801,86002900,86002901,86003000,86003001,86003100,86003101
86003200,86003201,86100001,86100101,86100201,86100301,86100401,86100501
86100601,86100701,86100801,86100901,86101001,86101101,86200001,86200100
86200101,86200200,86200201,86200301,86200400,86200401,86200501,86200600
86200601,86200700,86200701,86200801,86200900,86200901,86201001,86201100
86201101
$begin right shoulder joint info
right_shoulder_COG
900002
85006085
right_Shoulder_joint_Deformable_part
100003
89600600,89600700,89700700,89700701,89700702
right_Shoulder_joint_Distal_part
100004
  85000000  85000100  85000101  85000102  85000200  85000300  85000301  85000302
  85000400  85000500  85000501  85000502  85000600  85000601  85000700  85000701
  85000800  85000801  85000900  85000901  85001000  85001001  85001100  85001101
  85001200  85001201  85001300  85001301  85001400  85001401  85001500  85001501
  85001600  85001601  85001700  85001701  85001800  85001801  85001900  85001901
  85002000  85002001  85002100  85002101  85002200  85002201  85002300  85002301
  85002400  85002401  85002500  85002501  85002600  85002601  85002700  85002701
  85002800  85002801  85002900  85002901  85003000  85003001  85003100  85003101
  85003200  85003201  85100001  85100101  85100201  85100301  85100401  85100501
  85100601  85100701  85100801  85100901  85101001  85101101  85200001  85200100
  85200101  85200200  85200201  85200301  85200400  85200401  85200501  85200600
  85200601  85200700  85200701  85200801  85200900  85200901  85201001  85201100
$begin left elbow joint info
left_elbow_cog
900003
86006189,86006391
Left_elbow_joint_Deformable_part
Reno.
