Mathieu Reigneau
In 2022R2, the efficient way is scripting: have your origin/X/Y all set within a dedicated part, then record the assignment of the LED to one set of origin/X/Y, and edit your script so it repeats for all the sets in the dedicated part.
The simple way if your LEDs are regularly mapped is to create a pattern of the LED using the "Linear Pattern", "Circular Pattern" or "Fill Pattern" feature from the Design tab.
Coming 2023R1 next January, a new Speos Pattern feature will be available and will let you select a list of origin systems to automatically create and orient sources on each.
Thanks for you interest in our software 😉
