Saumadeep
Hi Robert, I have checked on my end and I see no such error. I have tried in ANSYS 2022 R2 as well.
I would suggest you to reset the app data and then re-download the geometry file and try again to see if the problem persists.
Follow the steps below to reset ANSYS Appdata:
  1. Exit ANSYS, if you are using it currently.
  2. Go to Start > Run
  3. Enter %APPDATA%
    1. A folder explorer window will open
    2. Open the Ansys folder. Look for the Ansys version you are using, for example, v222, and rename it to v222_Old
  4. Launch ANSYS and refresh the project
- Regards, Saumadeep
