Akshay Maniyar
Can you try using ‘Body operation’ option under ‘Create’ Tab in DM? Also, make sure that ‘Create solid’ option is set to yes.
Also, as Nikhil suggested you can use ‘Stich’ option under spaceclaim to stich the surfaces and convert the surface bodies to solid body.
Thanks,
Akshay Maniyar
