Akshay Maniyar
Hi Lovisa,
NLAD causes mesh changes during the course of the solution process, so there are some result scoping limitation which you can found at below Ansys help link.
Nonlinear Adaptive Region | post processing limitations
Also, you try suppressing all the output results and running the model. Then, you can unsupress results one-by-one and evaluate the results to find out which output result has issue.
Thanks,
Akshay Maniyar
